How to purge air from the boiler
simba
Member Posts: 19
in Gas Heating
Hello all
Can someone tell me how i can purge air out of the boiler not the zones i think there is air trapped in the boiler it self. When cycle is done i hear air bubbles for few seconds then it get is quite
Thank you
Thank you
Show us pictures, back far enough to see all the piping around the boiler and the expansion tank.
Also, what type of emitters.There was an error rendering this rich post.
Did you quickly crack the boiler supply or return shut off valve while purging? If you don't have the valve, disregard.0
