Replacement boiler for Munchkin T50
hysterwv
hysterwv Member Posts: 2
As the title states, I need to find a contractor and a reasonable replacement for my Munchkin T50 boiler. I'm in western PA and might have one of the older Munchkins around. It was manufactured in 2005. I rebuilt the thing two times, but now the exchanger has sprung a leak. I need a BASIC economical condensing boiler. It is used to heat the floors in my 40 x 60 pole building. I'm not looking for a ton of features. Quality needs to be average, not exceptional. It's only used when it's below freezing. Otherwise, we just heat the space with a Reznor furnace. Any suggestions on brand? I'd like to remain wall mounted if at all possible. It's nice to keep stuff off the floor in the shop.
Thanks in advance.
  • EzzyT
    EzzyT Member Posts: 1,380
    Where in Western PA are you?
    Check out the HTP ELU or the EFTU models I’ve installed a bunch of them, there simple and easy to maintain.
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
    Rich_49
  • hysterwv
    I’m in the east suburbs of Pittsburgh.   Murrysville specifically.
  • kcopp
    kcopp Member Posts: 4,699
    I would highly recommend the IBC HC 13-50. Simple design. only 5 moving parts.
