Restarting a system 2000 boiler
Good morning.  How do restart a system 2000 boiler
  • SuperTech
    SuperTech Member Posts: 2,669
    Call a pro. If you have checked the switches and breakers and the power is on that is everything a homeowner should do. If the burner needs to be reset that is an indication of an issue that requires a technician who is familiar with Energy Kinetics boilers.
    HVACNUT Member Posts: 7,526
    Which Energy Manager do you have? Are any lights blinking?
    You can try turning off the power to the boiler for a few minutes. If that works, great, but it might happen again. When was its last maintenance?
  • JayMcCay
    JayMcCay Member Posts: 43
    There is nothing special about restarting a System 2000 boiler compared to other boilers. If it is not running, the Energy Manager control diagnostics may give you additional insight into why it is off. If the burner is locked out (primary control latch up), it should be resolve as any burner lock out.
    @SuperTech and @HVACNUT both mentioned basic steps. Installation manual links and helpful resources for heating professionals can be found here:
    https://energykinetics.com/heating-professional-resources/
    Thank you,
    Jay
    Jay McCay
    National Sales Manager
    Energy Kinetics
    908 328-7154 cell
