Zone valve sticks open
Joe64
I have a zone valve that sticks open. If I hit it the valve will close. The valve is only 4 months old. I have a three zone boiler and I replaced two of the valve. One of the new ones is the one sticking. Any suggestions. They are Honeywell valves. Thanks
@Joe64
Send it back for warranty. Or you could pull it out or take the actuator off and try and determine if the problem is the valve body or the actuator1 -
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
