Gas pressure regulator problem
RayWohlfarth
RayWohlfarth Member Posts: 1,897
Greetings,
Just curious. I recently found two gas pressure regulators with a frozen cap. I tried pb blaster with no luck. Do you have a secret way of removing the cap when it is stuck? I was afraid to break it.
Ray Wohlfarth
Boiler Lessons
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,009
    edited February 2021
    Hi @RayWohlfarth , That's a strange shape to grab, but if you can find a square socket, that might give you sufficient bearing surface. Or cut a square hole in a piece of steel plate so it's a snug fit, then use a wrench on the plate while holding it down firmly. Also, tightening and loosening repeatedly and maybe using a hammer to tap on your wrench in both directions and "worry" it loose. What fun! >:)
    Yours, Larry
    ps, If you can find a piece of heavy "C" channel, 2 or 3 feet long. Cut that square hole in it at the center of the length and now you'll have yet another specialty tool to work with :p
    EBEBRATT-Ed Member Posts: 19,586
    Never had that happen usually a pair of Channel locks and it's off. Doesn't look corroded but you know how aluminum gets.
    Guess I wouldn't put a torch on it, LOL :)
    I guess some Kroil oil or something. There is usually a gasket underneath the cap maybe that is gone and it froze together.
    Suppose you could get a new cap and cut that one out
    Never Seize works wonders
    Maybe some light tapping would knock out the aluminum dust
    Makes me wonder if water got i the vent line
    Suppose you could disconnect the vent line and split the regulator to take it apart. Then you could turn it upside down and fill the cap area with Krol oil and let it soak
    Then with the top of the reg removed put it on the bench and heat it a little
  • JUGHNE
    JUGHNE Member Posts: 11,513
    I've had this happen, I just tap it pretty good with plastic hammer.
    Then Knipex pliers get a good bite on the cap.
    Some are plastic.
    PC7060
  • RayWohlfarth
    Thank you all. That regulator is not the one I was referring to. I forgot to get a picture when I was there. There is lots of moisture in the boiler room and I guess that is what caused it to seize
    Ray Wohlfarth
    Boiler Lessons
