Could a brand new brown boiler be cracked?
jdp1219
Member Posts: 41
in Gas Heating
Just got a new Crown boiler installed and after letting it run for the first 5 minutes, a liquid and something burnt up dropped near the pilot. My friend said it could be something burning off since the boiler is brand new. I'm afraid its cracked. Anyone hear of new boilers dripping when they first run because of factory chemicals or joint compound melting?
Is it hot water or steam?0
Hi, I am not a pro, its possible during the install your service provider may have left something unintentionally... it sounds like you have a gas boiler... I would call the people who installed it right away... dont try to fix anything, perhaps this might be a job for pros who installed the new boiler.... best0
The good news is if you don't see water leaking it's probably not cracked0
I saw water leaking for the first five minutes and then it stopped. A few drops came down and hit the pan under the burners.0
About 10 drops of water. My initial fear was that the boiler was cracked. After about 10 minutes of running, it stopped dripping. I think you may be right about the condensation. Is this something that occurs with new boilers at the very beginning? The sight glass was half way full.Youngplumber said:Condensation possibly. When you say leak what do you mean?
How full is your boiler?0 -
The install installations may have had a boiler pressure testing procedure.
Once set in place, all openings are plugged water tight and then the block pressurized with house water up to 30 or 45 PSI. Must hold pressure for some stated time.
What you can do is when the boiler is cool, overfill up to the header and let set for an hour. Leaks would show up dripping perhaps into the burner compartment or where you saw the initial drip.
Could you post pictures of the boiler and piping, everyone is curious to see new installs.1 -
Here is a video of the new install. I actually made it to send to some one so disregard the commentary at the end.
https://youtu.be/aJwpP0BHUNM
