Help identifying vintage Cast Iron baseboard manufacturer
williamlawler
Member Posts: 2
I am the proud owner of a 1901 classic colonial which now has a new Crown gas boiler and vintage CI baseboard radiators. I purchased as is knowing i was going to have sections of CI to replace because the previous boiler was Weil McClain oil which ran out of oil in the winter and 4 sections in 2 rooms cracked. I have been unable to identify the manufacturer of the CI but the previous owner left me a 3 piece unit pristine which was to go in a semi gutted bathroom. The pictures are attached. What's interesting are the 3 rows of fins on the back - have not been able to find this any where. One of you older guys must have seen this somewhere - it is the same throughout the enter house. Thanks in advance for your thoughts. Bill
Hmmm..... I don't recognize that model- but here's one that looks similar that you could use for replacement:
https://ocsind.com/products/cast-iron-baseboard/
These sections probably won't fit with your existing ones, so you'd have to replace the complete assembly, but you could then save any good remaining portions as spares.Baltimore, MD, USA
Consulting0 -
I am not sure where you are located.
This looks like a match.
https://maine.craigslist.org/mat/d/scarborough-cast-iron-baseboard-hot/7260982333.html1 -
