Left and right Radiator valves
RICK BONELLI
Member Posts: 5
I came across a steam radiator in a old catholic school in Brooklyn that has the radiator shut off valve and what appears to be a radiator thermostatic trap on the same side. Both have no unions so are L & R threads. Could anyone explain the history.
The only thing I can think of is like a turnbuckle for the last fitting or nipple because otherwise I have no clue as to how the parts could have been assembled, unless some joint is welded, glued or brazed.0
They must have screwed the valve and trap on first and then screwed the pipes up through the floor0
Definitely right-and-left-hand nipples. the threads in the valve and trap bodies are left-hand, while the ones in the rad are right-hand. You had to catch both threads and turn the nipple to tighten them up.
What make was the trap?Baltimore, MD, USA
Consulting0 -
I do not have the make of the trap. I do remember reading about this type radiator. I believe Dan H. wrote something about it. Did anyone read the article or posting?0
- 125 Chimneys & Flues
- 19 Recall Announcements
