Hot Water Radiator Vent Valve
RobLund
Member Posts: 10
I got mine at local supplier in Maspeth, NY with no issue. I am sure that you will find them in any plumbing store (not a chain hardware store).0
Did they look like this one?
That is just a standard coin key vent. Most of the hardware stores around here have them.0
Not quite the same style but very close:
https://www.supplyhouse.com/Matco-Norca-CKU-102-Key-Air-Valve0 -
As you may have guessed I am in an older home. 1928 vintage and am trying to keep with one closer in looks to what I have. I may have to go with this one and will see if it is available here at a Hardware Store.0
I found one from the following company that looks virtually the same, see attached photos. Castrads.com located in Brooklyn, NY. Yes more money but I am concerned with matching the look as much as anything.0
Great looking, even able to slip a rubber hose on it to control air/water blasts.
All ready to paint..... :'(0
