H B smith tankless coil
islandexpress10
Member Posts: 1
in Oil Heating
Hello what size are the studs or threded rods or bolts as you would say coming out of the boiler and what size nuts are they attach to threaded stud
Measure them. Can I assume you need to replace your thankless coil?
I believe the thread size is 3/8" course but I could be mistaken. the smallest I have seen is 5/16" course. The nuts are wider than the standard hardware store version so, if you are replacing them you will want to add a flat washer.
Some manufacturers use a threaded hole in the boiler and bolts, and I remember ThermoDynamics used a flange on the boiler with nuts and bolts so when you broke off the nut it was easy to replace without drilling and tapping the boiler casting.
I have also seen the somewhat rare 7/16" which I still mistake for 3/8 most of the time.
3/8" is most common.
Do yourself a favor and use anti seize on the threads if you get it apart0
