Use of Viega Propress Baseboard Stiffener
rossn
rossn Member Posts: 136
I purchased a few of the Viega Propress stiffeners that are intended for use with the thinner-walled baseboard copper.
However... they don't slip in! Instead, it looks like the OD is just a tad bit large for the ID of the radiator tubing.
The radiator tubing measures at 0.875 OD, with about a 0.018 wall thickness.
Should I need a mallet to tap it into the radiator tubing (not my first inclination) , or do I have another issue going on?
  • Intplm.
    Intplm. Member Posts: 3,081
    I have soldered all baseboards mostly because of the tight spaces that a propress jaws would not fit into.
    That being said. You do need to tap the stiffeners into the thin wall copper tubing.
    Ream the tubing before you start.
    kcoppSTEVEusaPA
  • STEVEusaPA
    Or solder on tail pieces so you can press where it's easier/more convenient.
    Intplm.
    mattmia2 Member Posts: 17,462
    I found soldered on propex fittings to be great for this application.
