Valve handle
dennishowell
Member Posts: 1
I have a house built in 1948 which has a hot water heat system. I believe the boiler is the original although I have replaced the pump once. It has 4 zone valves which work perfectly, but each room baseboard heater has what I assume is a mixing valve.
In two rooms the mixing valve on the baseboard heaters are broken. They appear to be Bakelite and have a 5-sided opening for the valve stem. The handles are marked "Webster System Camden New Jersey".
Any ideas on where to find replacement tee handles?
Can you post some pictures?8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
