Pressure transducer
AMservices
Member Posts: 613
Does anyone use pressure transducers for controlling steam pressure?
If you do, what brand do you use?
Recently had a vapor-stat that refuses to close after opening.
I've used a company out of NJ in the past for vacuum switches, but they've closed there doors.
I want to. I have a pile of IFM effector pressure switches I saved from some scrapped CNC machines. The old fixture air seat check switches operate on low pressure ranges, so they fall in the perfect spot.
They are programmable as field or hysteresis, NO or NC, two outputs, delay-on and delay-off timers up to 999 seconds. They operate on 24VDC, so a 24vdc power supply and a relay would be needed. My plan is to leave both primary and secondary pressuretrols in place and have this do the heavy lifting while the mechanical controls are a safety backup.
I use one on my well pump driving a 30A contactor. It is very nice. They have a digital readout too so it is also a gauge at the same time.
Thanks guys. I'll explore those options.
The couple I've worked with on vacuum systems were very accurate maintaining 12Hg to 6Hg. Im surprised there not more common place with steam considering how many people have problems with pressuretrols and vapor-stats.
Something simple and reliable with only a couple settings like 8oz-4oz, 16oz-8oz, or 2psi-1psi. That way no one can come in after you leave and crank up the pressure.
- 120 Geothermal
- 394 Solar
