Plumbing a manifold off a 2 pipe forced hot water system
Can anyone post a schematic of a hot water heater boiler with a manifold piped off the supply and returns for 3 zones? I plan on adding in radiant heat for my kitchen and bathrooms separately using 1/2”
    EdTheHeaterMan Member Posts: 12,442
    Many of us can. The question is Will We?
    Do you currently have a single zone connected to your boiler?
    What radiators are you using: Cast iron, Copper/Alum fin Baseboard, Convector?
    What radiant heat are you adding: Staple up under the floor, Gyp-crete thin pour on the floor, other?
    is this the type of "manifold" diagram you are interested in?
    From the presentation I used for teaching Hydronics.
    hot_rod Member Posts: 27,703
    Flo-control on the suction side of the circ? B&G typically shows them down stream? I like you lower temperature placement better.
    edited November 2020
    Take that up with Dan. He wrote the book I stole it from.
    but don't be too hard on him, he's still learning
