Aquatat L1848J issues
cbassett
cbassett Posts: 22
edited October 2020 in THE MAIN WALL
Hi everyone,
I just installed a new AquatatL1848J on my boiler (along with a new expansion tank, pressure relieve valve nut and automatic pressure vent) and I can't get heat. The boiler turns on, the water heats up but I can't get it to send out the water when the thermostats call for it. I have 2 zones with separate thermostats and it isn't working for either so I am fairly sure it is not the thermostats or the zone valves causing the problem. I labeled all my wires and rewired it based on the labels but I am wondering if I messed up. I am thinking it is the T and TV connections that would be causing this particular issue but I don't know enough about it to be sure. For fun both wires are red so its difficult to tell which is which and they both lead out to red wires on the zone valve motor boxes.
For some reason it won't let me add a picture so here is a link to the photo of my aquastat in case anyone can see what I did wrong.
https://photos.app.goo.gl/dLmsCJZnVWabFqkr9
