Home running CI rads off a manifold
Mbyrnes92
Member Posts: 16
Looking to repipe my house with pex al pex using home runs off a manifold to rads. I have the existing b and g pump still on the boiler on the supply side, can I use that with this setup? Also, would it be wise to look into a manifold with a mixing valve option? Any info would be greatly appreciated.
We would need to know what kind of boiler you are using and what water temperature you will run the system at0
Old Beckett oil burner with 155000 btu I believe0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
