Honeywell delay settings
dozerguy2
Hello I’m not a hvac by trade, however I did got to school for 3 years vo-tech of hvac main thing I learned was everything in this trade is frighten heavy! My hats off to all you plumbing and heating career guys👍
My question is I have a miller hot air furnace in my garage and I just cleaned her put in a new chamber and decided to upgrade my primary control to the Honeywell R7284U I also have the Beckett clean cut pump w/the clean cut solenoid
what should these delays be set at—
Valve on delay—?
ignition trial—?
burner off delay—?
spark in on delay y—or—no?
spark during run y—or—no?
so until I know the proper settings I will leave the new primary control in the box and let my old control run a bit longer.
Valve on delay—?
ignition trial—?
burner off delay—?
Thanks in advance
Do you have a combustion analyzer and a smoke tester?
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
