A Hundred Years From Now
HeatingHelp
HeatingHelp Administrator Posts: 722
edited October 2020 in THE MAIN WALL
In this podcast episode, Dan Holohan reflects on the work and the unsung heroes behind it. We are surrounded by inspiration because so many tradespeople take extreme pride in their work. You may be one of those people. If you wipe a solder joint correctly, even though the carpenter is going to sheetrock the wall and no one will ever see that beautiful joint again, you are one of those people. You do such things because you care — not only about your reputation, but about the building in which you are working. You want both to last.
Listen here.
ttekushan_3Steve MinnichHenry
