fire box
jsmith6752
I am working on a well mclain boiler. It needs a new fire box. It dates back to 1985. The fre box is no longer available. Linn does not make on for a model 86. Any suggestions? thanks
Is this a residential boiler. The model is 86 not 68? Even though around '85 the current model was the 66 series. Is there a yellow sticker with a code that starts with CP? Call WM with that code and they might be able to help.
What condition is the rest of the boiler? Pics? Wet pack and kaowool blanket?0 -
The 86 series was the predecessor to the current 88 series. It was a larger commercial-size boiler made in the 1970s and 1980s.
I have an old W-M CD that shows discontinued models like the 86. The firebox is not listed. But, you can make the necessary refractory pieces using Kaowool blanket such as Lynn #9450. Cut it to fit the front plate, target wall area and floor of the chamber, and secure it in place with plenty of Waterglass adhesive.
What is the exact model number? What burner is on that boiler?0 -
It's a serious boiler. The smallest 86 is about 800k BTU/hr0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
