Boiler closet heat
Kckfly001
Member Posts: 1
I have a small house slab construction about 2000sq’. Half is an addition, slab construction as well with in floor heat. The boiler for the in floor Heat is in a closet in my walk in closet. I have added fresh air ducting to manage the need for combustion and that all works good.
The room gets really warm and I would like to find a way to get that heat out into the great room which is on the other side of the wall from the boiler closet.
I have looked at thermostatically controlled fans to blow the heat out but never found anything I felt would work well.
I would greatly appreciate any input from the group.
Thanks in advance!!
try this:
add this fan. looks quiet and can be programmed the temperature you want, looks affordable
https://www.acinfinity.com/home-ventilation/crawl-space-basement-fans/airtitan-t8-n-crawl-space-and-basement-ventilator-fan-temperature-and-humidity-controller-ip-44-rated-intake/?gclid=CjwKCAjwjqT5BRAPEiwAJlBuBfBHKNEYIDSP8lPdEl9aG9qW7qo_vkh9lUddMCd07PHpN5nG6paOOxoCbsoQAvD_BwEEdward Young Retired
Also, insulate as much as you can to reduce loss from the piping in to the space.0
- 119 Geothermal
- 394 Solar
