York furnace flashing a 10 code
Saints
Saints Member Posts: 2
Our furnace has been working great for the last 9 years, have only had to replace the exhaust blower. So I checked the wiring, vacuum switches, cleaned the flame detector, and checked the ignitor. Any ideas on what's going on?
  • rick in Alaska
    rick in Alaska Member Posts: 1,526
    An error 10 on the York says it is sensing flame with the gas valve off. It could be a bad gas valve that is not shutting down, or possibly a bad sensor that is reading it. Either way, you need to have it checked out right away by someone who is familiar with this. If it is a leaking gas valve, it can be a dangerous situation.
    Rick
