Viessmann Vitorond 200 Issues
Hello all, I was wondering if anyone with a Viessmann boiler has any issues with fuses blowing or any other control issues?. I have a Vitorond 200 oil fired boiler that is original to my home (2003) and knock on wood has been great. But the other night i had no heat. Went to investigate and i saw a black smoke mark above the fuse holder on the control panel. The fuse was clearly blown but it melted the fuse holder altogether. I pulled the spade terminals and just put a standard 5 amp ATC fuse in and i have been back up and running with no issues for a week now. I just found it odd that such a major blow would happen out of the blue.
  • Robert O'Brien
    Robert O'Brien Posts: 3,611
    Dekamatik or Vitotronic?
  • 1075NH
    1075NH Posts: 34
    Sorry, its the Vitotronic
  • GW
    GW Posts: 5,257
    That’s a bugger. I’d get a 3 amp popper fuse on there and then go through all the relays and see if you can get it to pop. It could be a wild fluke- maybe a surge went to the boiler circuit
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
    HVACNUT Posts: 7,746
    If it melted the fuse holder with a 5A, then it probably originally had a 3A.
  • 1075NH
    1075NH Posts: 34
    I'm thinking it may have been a surge as well. The fuse was original and it's a 6 amp which is an odd size but thats what it calls for. I am going to wire in an ATC Fuse folder and get a 5 amp fuse for it. WAY easier to change and to find locally then the glass fuses. I also want to wire in a hard wire surge suppressor to the boiler. And now that i see how uncommon this unit is, i want to try and get a replacement control board and keep it on hand.
