How does this flame look
Northupthere
Northupthere Member Posts: 35
edited March 2020 in THE MAIN WALL
I had the tune up and filter installed last week in this Buderus / Riello and there wasn’t even any ash or soot for him to vacuum. He left the Turbulator set to the sticker recommendation of 2. I guess these burn cleaner than my old house it had a Weil McLain. Video link below.
https://streamable.com/oz0wf
  • STEVEusaPA
    The only thing looking at a flame like that tells a professional is that the burner is firing. Or initial set up on very old equipment.
    Anyone who, after a tune up, doesn't do a combustion analysis and declares "the flame looks good" is a hack.
    What were all the combustion numbers including draft?
    Solid_Fuel_Manicy78SuperTechB_Sloane
  • Grallert
    Grallert Member Posts: 1,169
    Looks like a flame. Did the tech leave you with a printed sheet of the combustion numbers? They're the tell.
  • Northupthere
    He didn’t have a printer so I wrote these down
    86.5% eff.
    10.50 dioxide
    6.9 oxygen
    draft in the exhaust us .01 or .02
    Carbon monoxide is 10ppm
    excess air is 40
    0 smoke
  • Northupthere
    What surprised me is there’s no soot or ashes I don’t know when the previous owner cleaned it the house was a foreclosure
  • Grallert
    That combination G115 and Riello seems a great match. Very clean and build up free systems in my experience. I've installed dozens and serviced more. I assume you mean CO2 when you write dioxide. In my experience that number should be higher, closer to 12.5%. That will lower the o2 and the excess o2. You don't mention the flue temp.
    SuperTech
  • Northupthere
    edited March 2020
    Yes it was the carbon dioxide , the flue temp showed between 355 and 365 give or take. The room temp was 65ish. He did close the air shutter some but there was a 1 on the smoke scale so he left it the way it was for a 0 smoke
    It has this label on the burner. It’s the same color as the boiler but the front boiler piece wasn’t here when I got the house so it looks weird. I wonder how much one costs or even if it’s available.
  • Grallert
    I'm not sure the front boiler cover is available. It's worth a look around. It's mostly to finish the boiler but it does offer a little sound and heat insulation.
  • SuperTech
    SuperTech Member Posts: 2,669
    Your tech isn't familiar with Buderus and Riello. Oxygen is way too high.
  • Northupthere
    He tried closing the air shutter some but that gave a 1 smoke, how else would it come down?
  • Grallert
    There could be more going on here. Pump pressure nozzle size head setting etc. or a combination of any or all of those. I'd try to get a better co2 number but what you have isn't the end of the world.
  • Northupthere
    Yea I guess it’s running clean and it certainly isn’t using a lot of fuel or smoking and sooting things up. I’ll have to look into it more at some point.
  • SuperTech
    The draft over fire measurement is critical with that boiler. I'd make sure that the draft is where Buderus specifies before worrying about the O2/CO2 and smoke.
    Get the draft correct, then set the combustion.
    STEVEusaPA
  • Northupthere
    Surprisingly they left the manual it says 0 to slightly + I’ll take that brass screw out for the guy and have it checked. He didn’t want to break the glass so I’ll take it off to ease his mind
  • SuperTech
    You don't have to touch the glass or remove it. There should be a brass fitting right next to it with a flathead screw in it. Loosen the screw, attach a manometer hose over the fitting and read the draft on the manometer.
    HVACNUT Member Posts: 7,589
    Forget about the glass. The glass is useless.
    The tech should have a small control screwdriver. You just loosen the screw. Don't remove it. One turn. Righty tighty lefty loosey.
    It seems like he doesn't have a manometer to check.
