Foam panels that tubing lays into
solradman
Member Posts: 58
Any recommendations for a radiant foam panel for 1/2" tubing? I find info on Crete-heat which is thicker than needed. Seen pictures of a orange panel but no product name.
Not exactly sure what your looking for but I have seen the following in person and it looked pretty good to me.
https://www.viega.us/en/products/Catalog/Heating-and-Cooling-Systems/Heating-and-Cooling-Solutions/Panels-Plates-Tracks-and-Mats/Viega-Rapid-Grid-2857-2US.html0 -
for a concrete pour? I don't think you would want to go less insulation thickness.
Or for a dry system?
I like the Roth for dry systemsBob "hot rod" Rohr
Living the hydronic dream2 -
We used a similar product to the Beaver Plastics, but because of funancial and supply considerations just used it at the edges of the rooms, for holding the bends in place and inground certified sheet foam where the runs were straight, saved us some money and worked out well.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 114 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 49 Job Opportunities
