Cast iron baseboard btu’s
vizio
Member Posts: 1
I have a customer with a 6 tube 19” high ,7” deep ,20 Section , 35”long hot water radiator. Each section is 1.75”thick. How many btu’s will it supply?
I can't find that radiator in my book, but a four tube, 20" high, 7" deep is 2 1/4 square ft/ section so:
2.25 x 20 sections=45 sq feet of steam. 45 x 240=10,800 btu/hour on steam
'0 -
An ARCO radiator by American Standard shows that the EDR is 2.3 sq ft per section. So, a 20 section rad of that size has an EDR of 2.3 X 20 =46sq ft. 180degree water would yield 170 btu/sq ft or 7820BTU/hour. If you are interested in down loading the ARCO catalog, go to the "main site -museum-radiators. Hope this helps.0
@vizio, my bad. Thought it was steam. Looks like @retiredguy found it0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 975 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
