weil mcclain 97+ hot water boiler - low water cutoff open ( system lock out / heat not working )
yogi802
Member Posts: 6
can some one help please
hot water boiler
weil mcclain 97+ ( installed in 2013 )
showing error message in RED
system: lockout
will appreciate your guidance / help ASAP
hot water boiler
system: lockout
assuming the low water cut out is not faulty and its doing its job, i'd say your boiler is low on water. whats the pressure gauge reading?0
pressure gage is down - around 10 psi0
That pressure could very well be the cause of the trouble. Try bringing the pressure up to near 20 and reset the boiler.
Can you post some pictures? When was the last time it was serviced?Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
