weil mcclain 97+ hot water boiler - low water cut off open
yogi802
yogi802 Member Posts: 6
my hot water boiler is not working, showing above error message
can some one help ASAP please
installed in 2013
  • SuperTech
    SuperTech Member Posts: 2,653
    First thing I would do is check to make sure that the boiler has enough water in it. What does the pressure gauge read? Sometimes this problem can be the result of a dirty low water cutoff probe.
  • yogi802
    how do i check water level ? sorry for my ignorance but this is first time i am having issue with WM97+
  • yogi802
    pressure gage is about 10 psi now
    appears to me dropped from about 16-18 psi before ( luckily i have one picture to compare )
    hope this helps !!
  • icy78
    icy78 Member Posts: 406
    Did you check the install manual troubleshooting?
  • yogi802
    yes but you can see asking to check water level - not sure how to do this ?
  • DZoro
    DZoro Member Posts: 1,048
    If it has been some time since it was serviced, now would be a good time to have a complete service/cleaning done to it.
    D
