hot water baseboard
captkirb
Member Posts: 1
after a service, weil boiler w/ hot water baseboard w/ 2 zones w/ zone valves, the downstairs zone will not heat unless the upstairs zone is on and pumping. i suspect a circulating pump wiring problem. any thoughts on this would be appreciated
Take a look at zone valve. Is it in the hold open/manual position.0
