Does anyone know which make and model this radiator is??
Ormonde
Member Posts: 2
Does anyone know what make or model this heating rail is.
I am trying to replace some missing parts but do not know what they are as I do not know what it looked like when new.
Would love to find the missing parts.
Can anyone help??
Thank you
Can anyone help??
Thank you
The 2 items that you are showing are isolation valves. The right hand valve is a square headed key valve. You should be able to buy a replacement key at a hardware store, plumbing shop, home depot or lowes. Also, you may be able to turn the valve using a 12 or 8 point socket. Also try a search for a square head key valve.The left hand valve may just need a new handle. (need a better view with that washer removed).0
Retired guy- thank you so much. I will attach them left hand valve without washer below
Thanks so so much0
- 119 Chimneys & Flues
- 114 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
