Controlling Variable Speed ECM Circulators Grundfos Alpha with AutoAdapt
If you use this type of circulating pump do you require a pump controller.
  • Paul Pollets
    Paul Pollets Member Posts: 3,672
    The pump usually wires into the boiler control or computer or a relay box.
    hot_rod Member Posts: 28,085
    What type of system do you have zone valves, TRVs? Which model Alpha? Some models have a summer function which exercises them occasionally to prevent sticking over no use periods, so they need to be plugged in to a constant power source to use that function.
    https://www.youtube.com/watch?v=J_elAwebxcE
