One Radiator Cold
saf630
saf630 Member Posts: 2
Hi- I live in a row house with about 6 radiators. One of my second floor bedrooms (furtherest from the thermostat/basement) does not get hot (or even warm, it's completely cold). I have bled the radiator already and played around with the valve, which does leak with cold water when I took it apart with a pair of piers. My radiator only has a valve on one side. Any other easy ideas/tips before I pay for a professional? Here are a few pictures: https://imgur.com/a/5J6sDwW
  • Big Ed_4
    Big Ed_4 Member Posts: 3,362
    I would need more info , it looks like the system was redone , neatly done but not correct orit would work .
  • JStar
    JStar Member Posts: 2,752
    That's a steam radiator, which means that it's not connected on top, only the bottom. Water will take the quickest route right to the return. Does only the bottom get warm? Does the valve get warm?
  • saf630
    @JStar Nothing gets warm, not even close.
  • Big Ed_4
    From here you did what you can and nothing looks incorrect .
    saf630
  • JStar
    Is this the only radiator with this issue? Was anything changed recently? Do you have access to the piping that goes to this radiator from the main system piping?
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,362
    There were two threads going about this, so we've merged them into one here. Thanks!
    President
    HeatingHelp.com
