Does anybody know the edr of this Radiator?
We have an apartment full of them. They are all 3 inches deep, but come in 17, 20 and 23 inch heights. WE are orificing this system of about 225 rads and need to know the edrs for sizing the orifices and checking the heating balance with the surrounding units.
Thanks!
    mattmia2 Member Posts: 16,896
    i feel there is a picture missing here.
    Steamhead Member Posts: 18,529
    @The Steam Whisperer - let's see some pics!
    Consulting
  • The Steam Whisperer
    The Steam Whisperer Member Posts: 1,316
    Go with that feeling.......
    Cast-iron, or steel with fin-tube inside?
    Consulting
    IIRC its steel, you can see a dent about in the middle. No sure about the fin tube. I can probably go back and check
    thanks,
    "E.D.R.", page 243.
    Consulting
    Intplm.STEVEusaPAvaporvac
    Sure enough, Didn't see those.... thanks!
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    Those are a very nice convector! They were available with front outlets like you have and also top outlets. The installation I am familiar with was on hot water, 1954 construction.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
