Having issues with my boiler
jamesu633
jamesu633 Member Posts: 1
So I started my boiler for this winter. And it started up just fine. And 4 days later its tripped off. So I go and reset the boiler. I noticed the motor not turning on right away. So I use the palm of my hand to smack the transformer box. And then the motor kicks on. And I have to repeat this process for the past few days anyone have any possible ideas of what this could possibly be?
  • Jellis
    Jellis Member Posts: 232
    i would GUESS bad burner motor, but very possibly another issue.
    Stop beating your burner... it's good to you! it keeps your warm... you are likely to damage something else by beating it and be worse off than you are now.
    A pro can successfully test the motor to verify if it is bad.
    jamesu633STEVEusaPASuperTech
    HVACNUT Member Posts: 7,664
    It could be the burner motor, fuel pump, or coupling.
    Giving it a smack tells me its probably the motor.
    What brand and model burner?
    mattmia2 Member Posts: 18,026
    Or a contactor depending on what gets jostled when you smack the motor...
