old vacuum system - need help identifying
Steve_210
Member Posts: 664
Hi Guys -
This looks like an old vacuum system. Can anyone identify it? Just want to know a little more about it before I change any radiators.
Probably a Paul system or similar. Is there a name on the air vent?All Steamed Up, Inc.
Consulting0 -
Is that vacuum vent line lead?0
Cannot see any markings on the air vent,
Pipe is black steel not lead thanks0 -
Just install a one pipe radiator seems to work fine0
Old one pipe vacuum systems were used on coal fired systems. with the advent of oil and gs fired boilers the systems did not work right. The best you can do is to replace any and all vacuum type air vents and replace them with Hoffman #40 vent valves.
Additionally, Replace the main vent on the steam main with a Gorton # 1 or a Gorton D vent valve. Both are high capacity vent valve. The difference is the shape and physical size of the valves.
This will leave you with a simple one pipe steam system.
Set the steam pressure to no more than 3 PSI off and 1Psi ack on.
Jake
Steam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0 -
Thank you it’s an apartment building cannot mess with the boiler but thanks for your help0
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
