Giannoni heat exchangers
kev
kev Member Posts: 100
Velocity Phantom boiler needs a new rear firewall. Wondering how it is attached to rear of chamber. I say Giannoni heat exchanger and thats an assumption for reference. Thanks for any help.
  • HomerJSmith
    HomerJSmith Member Posts: 2,710
    Doesn't look like it's fastened at all. The burner tube looks to keep it in place. You can check for a screw in the center of the refractory.
  • JUGHNE
    JUGHNE Member Posts: 11,513
    Some have a very small Allen screw and washer holding them in place. If so I shot a little WD-40 to soak awhile and then a little turn tightening and untighten, I had to go back and forth several times in and out until it got loose.
    Then a large sharp tweezers to poke it near the top and walk it out......that might be all you need to do for this one.
    The one I removed was not in terrible shape and I just flipped it over to reinstall after cleaning.
  • clammy
    clammy Member Posts: 3,242
    I went to a class on them and when I asked they said you only need to cover when cleaning and removing wasn’t required . Personally when there’s a Allen I ll remove them I would see if it’s only held in place by the burner tube if so I would take it out to clean .you can see if a standard Allen key can make it behind the side to see if it will pop off . Peace and good luck clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
  • JUGHNE
    BTW, for me it was a metric Allen screw.....something you do not want to bugger up or twist off.
  • kev
    I don’t see a obvious screw. I’ll know better when I have the new part.
