Mica window on burner door.
This is on a Hydrotherm boiler that sooted up and destroyed the mica window. Is mica still available?
    EBEBRATT-Ed Member Posts: 19,577
    Don't know. I suppose you could use a piece of sheet metal in it's place pop rivit it to a spring loaded hinge or put it on with sheet metal screws
  • ScottSecor
    ScottSecor Member Posts: 1,020
    Haven't seen mica in a while.... Not that I'm proud of it, but I have been known to use a 1900 electrical box blank cover in a pinch.
    @ScottSecor
    Those box covers are quite handy. Their good for shimming boilers. Or on an electrical panel when the knockout comes out......you know, the one you didn't want to remove, screw the box cover to the panel and make a new knockout in the box cover.
