Weil-McLain Steam boiler - hydronic loop stopped working
axele
axele Member Posts: 2
We have a single pipe steam system. Works like a charm.
Unfortunately though the hydronic loop for our extension that is on a different thermostat
stopped working.
I can feel the pump starting when the thermostat is on 'heat'. But there is no warm water circulating
and the boiler does not seem to be on.
I feel the pump is running a bit hot. Like there is no water in it. But that might just be me projecting.
Entire system is about 4 years old.
Any pointers and / or suggestions would be much appreciated.
  • Jolly Bodger
    Jolly Bodger Member Posts: 209
    What you have there is a wet rotor circulator. They can get seized up and it is hard to tell besides the water does not flow. The motor will still get hot.
  • Snowmelt
    Snowmelt Member Posts: 1,457
    looked at the picture for 20 seconds and i can spot two things.
    one your don't need an expansion tank or air eliminator. If I went to look at it I would say looks like a rookie did it.
    you have air in the line you need to get the air out, did the installer leave some way to get the air out.
    mattmia2 Member Posts: 15,886
    There is a PRV as well, so I'm thinking it is using a tankless coil as an HX.
  • KC_Jones
    KC_Jones Member Posts: 5,912
    The tankless on that boiler would be located where that big round plate, so no tankless in this boiler.
    2014 Weil Mclain EG-40
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,520
    > @KC_Jones said:
    > (Quote)
    Tankless for that boiler is inside the jacket. Front left corner. On the left most section. Rectangular plate.
  • KC_Jones
    Must have the provision for both on that one then, didn't realize they did that.
    So then is that a tankless inside the jacket just below the service switch?
    edited December 2019
    Can you take a picture of the piping behind the expansion tank? Is there a drain in that pipe that transitions from iron to copper?
    Where is that aquastat? Is it inside the front cover on the lower left?
