Graphite Spray Coating
rhl
rhl Member Posts: 109
Hi,
I was wondering if anyone has experimented with spraying graphite lubricant onto the subfloor before doing a staple up job with the metal plates. Would this improve heat transfer at all?
  • STEVEusaPA
    I feel like it would make a mess, maybe even a smelly mess.
    Gordy
    hot_rod Member Posts: 27,703
    I'm not sure it would add enough value for the cost and hassle?
    Best to get a nice flat, clean subfloor and screw the plates as tightly as possible.
    It's the plate to floor air gaps or spaces that reduce the conductive transfer.
    GordyDaveinscrantonRich_49
  • Gordy
    Gordy Member Posts: 9,546
    Yeah something like never seize has its Own smell before heating. It also finds its way on everything else.........
    CanuckerSTEVEusaPA
