How to connect SR506 to Aquastat L8148A
dagc
Member Posts: 13
in Oil Heating
I want to connect a Taco SR506 switching relay to a oil fired boiler Well Mclain WGO-3 which has a Honeywell Aquastat L8148A connected to it. How do I connect the SR506 to the aquastat L8148A? Thanks
> @HVACNUT said:
> If all the circulators are in the 506, then simply run a thermostat wire from XX on the 506 to TT on the aquastat.
It worked, thank you.
One last question, although everything is working fine and just to be on the safe side. I jumped the T T at the burner, is that right?0 -
- 125 Chimneys & Flues
