Air vent needed here?
CBRob
CBRob Member Posts: 291
I'm used to seeing an air vent here.
Is one needed if there is another air eliminater in the loop?
What is the typical size for an eliminater located here?
I also am used to seeing them on top of the indirect water heater.
Is that typically a 1/2 mpt?
  • DZoro
    DZoro Member Posts: 1,048
    Yes that boiler comes with one specifically for that spot. It takes the air out of the H/E.
    That one comes 1/2" for that tee.
    D
  • CBRob
    Thanks D
  • JUGHNE
    JUGHNE Member Posts: 11,558
    What type of PVC is used for that exhaust?
    Is it foam core PVC or Sch 40 PVC?
  • CBRob
    edited November 2019
    Not sure, didn't look closely at it.
    I can check tomorrow.
    Does it look off?
    "Not for pressure"
