Axiom Puropal water conditioners for steam
Mark Eatherton
Greetings fellow Wallies. Has anyone here ever had any experiences with the Axiom Puropal water conditioners for use in steam heating applications? Positive or negative, looking for all feedback.
We have tested the water before and after and are impressed with the results, but did experience some water line bouncing (steam) after we installed the cartridge. I suspect dirt from distribution worked its way back top the vessel, bit wanted to see if anyone else has had the same experience.
Thanks for your input.
Mark Eatherton
Service Director
Advanced Hydronics, Inc.
Denver, CO
Mark Eatherton
Service Director
Denver, CO
check th ph after a few days, the cartridge could pull it down into the high 6. Steamers like to run a bit alkalineBob "hot rod" Rohr
Living the hydronic dream0 -
Thanks for the advice HR. It's only on the make up, so it only conditions upon draw, but will take you advice to heart.
Much appreciated.
ME
- 135 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Job Opportunities
