Replacing Weil-McLain Burner (M 710344)
kipbrau
kipbrau Member Posts: 16
Which burner would be the correct replacement for my old (1981) Weil-McLain Burner (M 710344)? P 465 is another reference # on the face plate. Thanks!
    Steamhead Member Posts: 18,554
    That's a model 4-65, which means a series 65 boiler having 4 sections. What burner is on it now?
    Consulting
  • kipbrau
    Weil-McLain Burner (M 710344). Thanks for your response, Steamhead. Kip
    HVACNUT Member Posts: 7,481
    The burner is just badged Weil McLain. The actual manufacturer should be on the housing. With "M" in the model, I'm thinking Wayne.
  • kipbrau
    The old burner #(M 710344) Wayne . Air tube length is 6", 80 degree nozzle (with .85 and 60P stamped on it). Should I replace this with AFII- 85 or AFII-150 (Beckett)? The old burner is circa 1981.Head "F" designation on ATC chart is a riddle. Any clarification is appreciated. I'm sure wading through these naive questions and concerns gets annoying to the pros. That said, thank you for any guidance and thanks HVACNUT for your reply!
    That might be a Wayne MS-R burner. Post some pics of the burner and the labels on it to be sure.
    If so, it is still a current model according to their website:
    https://waynecombustion.com/uploads/downloads/Brochure-Wayne_Full_Line_12-08_W_2008.pdf
    If not, I'd say a Beckett AF or AFG would be a good choice. You don't need a high-static burner like an AFII on that type of boiler.
    Consulting
  • kipbrau
    Mr. Steamhead! Thank you!!! And, thanks to HVACNUT. Not enough thanks issued in this Topsy turvy orb we live on. Cheers and more newbie queries forthcoming id this project du jour gets "oogy " (w/ apologies to Stephen King ((Misery)).
  • kipbrau
    Mr. Steamhead, the burner markings are MP 1160. It appears to resemble Model EASR-S (Wayne). Thx.
    Can you post a few pics of the burner and boiler?
  • kipbrau
  • kipbrau
    I believe the old burner is a Wayne, model - EASR-S, with MP 1160 punched in the chassis. Circa 1980 (?). Thanks!
  • Alan Welch
    Alan Welch Member Posts: 271
    While you have the burner out , check the condition of the combustion chamber/ target wall.
  • kipbrau
    Thanks, Alan. That is my plan and yet another non-pro learning curve to climb. Your reply is much appreciated! Oh, to be rich and hire a pro while I drink beer and worry about my car. :smile:
  • kipbrau
    Given the age of the boiler, I'm assuming the lining is asbestos. Another can of worms, perhaps?
  • STEVEusaPA
    The chamber is not asbestos, but recommended mask & gloves when handling. I don't really think it's wrapped in asbestos under the jacket, as it's probably a late 70's early 80's boiler.
    Also, a standard flange may not fit the bolt pattern exactly. You may have to hold it in place using large washers.
    Consulting
