Tips or Tricks for draining Amtrol Boilermate coil?
How much fluid(system is 85% water and ~15% glycol) should I expect out of an 40 Gallon Amtrol boiler mate? Replacing the unit, because it is leaking slightly and 20 years old.
Is it possible at the manifold to push air in there and flush fluid out there also?
D0 -
Well, the manifold is right behind the tank. So I think it would be difficult to get back there to cut the pipe to push air. Once the tank is out of the way it would be easyDZoro said:Is it possible at the manifold to push air in there and flush fluid out there also?
D
I am going to add a drain in the replacement.
If that is on a 2nd floor, wouldn't code require a pan for the water heater and the boiler?0
And where are the relief valves draining?mattmia2 said:If that is on a 2nd floor, wouldn't code require a pan for the water heater and the boiler?
You could have a crescent or pipe wrench on the copper female adaptor ready to turn the 90 elbow sideways immediately after you loosen the union, so that it ejects fluid into a pan. There shouldn't be that much fluid in the coil.0
No idea why there is glycol in it. I will take it with my truck antifreeze flush and fill and pay to have it disposed? If that is not ok then let me know.STEVEusaPA said:Why glycol and how do you intend to dispose of it.
On the new install, pipe in some drain valves, and stick it on a pan.
I am going to put 1 drain on boiler return which on the HTP is the lower of the 2. Should be good I hope.
edit: that is probably wrong... I guess 2 drains?0 -
Not a lot worries about code around here. Pretty remote. The relief runs through the floor around in the walls for about 15 ft to another room that has a drain about 3-4 feet away.STEVEusaPA said:
Going to change all that up a bit also. Several items outside of code(pan, not in the room, not visible, not less than six inches from the floor or drain) 0 -
I think that the union has to be loose for me to detach(threaded) it from the boilermate. So don't think I can spin it around to drain.psb75 said:You could have a crescent or pipe wrench on the copper female adaptor ready to turn the 90 elbow sideways immediately after you loosen the union, so that it ejects fluid into a pan. There shouldn't be that much fluid in the coil.
Edit: I think I get it. Yes I can turn it quickly towards a pan...
I assume I am going to get half of the "fluid" out of each side?0 -
Half out of each side? No not really. Its a closed, standing coil of fluid. Open one side and "a certain amount" will drain out. Open the other side and..."the rest" will drain out.0
So the wall side will be difficult to turn towards a pan. I assume then I should to that side first. Not much room to turn and no room for a pan. The second side should be easier to direct into a deeper pan, I'll do that side second.psb75 said:Half out of each side? No not really. Its a closed, standing coil of fluid. Open one side and "a certain amount" will drain out. Open the other side and..."the rest" will drain out.
can probably break the union and jam a wet rag in there until you can break the other and move it enough to get a shallow bucket under it0
Break the unions and use a shop vac to suck the fluid0
Get a small drain pan with a fitting in it, or put one on, run a garden hose downstairs to a bigger bucket or small drum. Problem solved. I always get a kick where someone puts a pan under a tank or water heater, and doesn't pipe the drain away. Once the pan is full, your back to square one, same as without a pan.1
- 87.5K THE MAIN WALL
- 123 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
