Boiler mystery- Crown hydronic boiler
pasquinnal
Member Posts: 2
So...I hear something running from the boiler the middle of the night, when it's very quiet. It sounds as if water is running into the boiler & it continues for 20-30 seconds, then stops. A minute goes by & it starts all over. No water leaks anywhere. Not sure what is making this noise but something from the boiler is since it disappears after I shut the boiler off.
Sounds like you are low on water. What is the pressure on the boiler?0
I'll try & find out later as I'm not at home currently. Thanks!0
Is this a steam or hot-water system?
Consulting0 -
Possibly air in the system.0
Circ exercising or freeze protection?0
- 125 Chimneys & Flues
- 19 Recall Announcements
