Flow Check Valve leaking, can I just replace the inside of the valve and no soldering?
darklunar123
Member Posts: 5
in Gas Heating
Yes, you can replace the insert only. Be sure to clean the brass seat inside before you pop to new one in.0
Thanks. Would I need to just unscrew the very top? Tried googling around and couldn't find any instructions on this.0
Thank you!!0
- 128 Chimneys & Flues
