Need advice on heat pump water heater
Hello, hoping I can get some advice here.
I want to replace my aqua booster with a HPWH, but I'm having trouble finding someone experienced with these.
Does anyone have any thoughts/recommendations for someone in the Miller Place area (anywhere?) who can do this work, or maybe a particular brand to recommend?
I understand that they're relatively new, but it seems the bugs have been largely worked out by now.
Thanks for any advice you can give.
Hi, I don’t know where the Miller place is, but you could search here using the find a contractor button. As to brand, look and see what brands are locally sold and supported. That should be a big factor in choosing equipment along with what the installing contractor is familiar with. Also, with heat pump water heaters there might be rebates or incentives to get one where you are, so have a look at dsireusa.org and see if any rebates are available to you.
Yours, Larry0 -
Thanks Larry.
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
