Odd size return grille needed
Does anyone know where I could find an odd size return grille It’s size is 38.5 x 34.5, and that is to the outside of the flanges. A whole house fan was there originally and it was removed when central air was added to the home. This is the main return for the four ton air handler that it is attached to, that is located in the attic.Any assistance would be much appreciated. Thanks to all.
  • STEVEusaPA
    edited October 2019
    You shouldve used standard size and parched patched the drywall.
    Next option is to probably get the closest size, make up with a wood frame, box out & trim.
    HVACNUT Member Posts: 7,507
    Does it need to be a filter grill?
    You might, might find a stamp grill that size. Whoops.
  • SeanBeans
    SeanBeans Member Posts: 525
    You can get them custom made to whatever size you want.. I recently had to get a 24x4 floor grill custom made.
  • STEVEusaPA
    Locally, or do you have a link?
  • zepfan
    zepfan Member Posts: 464
    Thanks for all the responses. No it does not have to filter grille. the filters are at the air handler
