Burnham ( US Boiler) Radiant Radiator Grill info
peters
peters Member Posts: 2
Thanks to a helpful tech person at US Boiler...the pins (2 per radiator) part number is 8084201, the spring J-clips (2 per radiator) that hold the grille 6084201. The grill installation instructions ( not on their website) are attached. If you need them you need to get them from your supplier, not US Boiler...Hope this helps someone.
