Opening EFFICAL vent damper.
I have an EFFICAL vent damper on a gas boiler. I am trying to light the boiler. When I move the switch to the "hold open damper" position, the damper does not move. I tried twisting it by hand, but it is too stiff. Any suggestions?
    Steamhead Member Posts: 18,504
    That damper is supposed to work automatically. If you twist it, you may damage the motor assembly.
    If the boiler doesn't start, you need to call a pro. Where are you located?
    Consulting
    HVACNUT Member Posts: 7,454
    The switch on the damper motor is to leave the damper open once its already open. Dont force it. Is there 24v at the motor?
