Why is the outlet of the Barnes & Jones BJ-3BM “Big Mouth” vent threaded?
jsavage
Member Posts: 44
I bought some Big Mouth vents and I’m curious why the outlet is threaded. Is it to handle any water that might spit out?
Thanks!
PS I did search for this answer, but feel free to just provide a link if this question has been answered before. Thanks!
Thanks!
Homeowner from Providence, RI
Home b. 1897, one-pipe steam with a indirect gravity hot air system using Gold's pin radiators.
They make the big mouth out of a trap body and trap bodies are threaded. + you can pipe the outlet to a drain to catch any leak0
Awesome, thank you!--
Home b. 1897, one-pipe steam with a indirect gravity hot air system using Gold's pin radiators.0 -
Just so you know, the Big Mouth vents do not have a float.
So is any water gets to it it will spill out.
I have put these up as high as possible. In school house class room they are on a 4' riser. I added a ball valve under them in the event something happens. I 90ed out the back and nipple down a couple of inches so any steam vapor might not cook the wall. So far so good.0 -
Also, so they can be used as crossover traps.All Steamed Up, Inc.
Consulting0 -
@Steamhead What is a crossover trap?--
On a Vapor system, we often find radiator traps piped between the end of the steam main and the dry return. This does the same thing as a main vent- helps air get out of the steam main quickly- but routes the air into the dry return so it will leave the system at the central venting point.All Steamed Up, Inc.
Consulting0
- 120 Geothermal
- 394 Solar
